1 - 9 of 9 Posts
2001 Odyssey, gas smell only after filling up. After gauge drops slightly below the full mark no smell. Any suggestions / ideas - Thanks!
I don't think it applied to Gen2, but the Gen3's had a recall for gas smell related to a faulty gasket on the fuel pump. Based on your description that would be a good place to look.
Check the filler neck in front of the rear wheel, seal might be going bad
Discussion Starter #5
Thank you! Will check gasket.
Discussion Starter #7
Than
Checked and gasket needs to be replaced-Thanks again! Would you know if the 2002 and 2001 gaskets are the same? I'm assuming they are the same but when checking for parts online, for some reason it says that it will not fit a 2001. I checked for fuel pumps and they the same for both? Thanks you!
According to RockAuto the same part number gasket fits 1999-2004. They sell a Denso gasket for $22.79
1 - 9 of 9 Posts
