hi, I have a 2004 honda odyssey and the "D" drive indicator does not light up any more. Also the "R" reverse light is intermittent. I can make this come on by jiggling the shifter. Can you tell me what part needs replacing and where it is located?
thanks
I "think" it is on the outside of the transmission housing. After my recent transmission rebuild, the dash gear lights were somewhat erratic, so the guy put another switch from junkyard and charged me for the part and one hour of labor. The neutral light is still iffy but the others are now working correctly.
After comparing pics of switches on the net I think its just on the lower side of the tranny(drivers side).
Does this sound right?
I see its held on by a couple of bolts and the plastic housing is screwed together. I wonder if it can be taken apart and fixed?
dealer here in Ontario wants $314 dollars for the switch so i'd like to salvage it.
