1 - 12 of 12 Posts
What should I keep an eye out for a common issue or some of the bigger issue with their VCM2?
It's listed for $6.5k.
2007 Odyssey EX-L
2009 was the last year the Touring model was offered with PAX tires and rims. You will need to convert them to regular rims and tires if it hasn't already been done so. PAX was an option in 2009, though, so it might not have PAX to begin with.
Reactions: WiiMaster
Thanks. Looks like the car has an aftermarket rim/tires. I'll confirm it when I go see it. This is the rim on the car currently.
159863
Find out if the timing belt was changed and if the VCM was muzzled or not.
The VCM function is known to cause piston ring damage, misfires, excessive oil consumption, vibration and failed engine mounts. Ask if this vehicle has or had any of these issues. Ask if the VCM function was disabled (muzzled).
Most knowledgeable owners of VCM Odyssey’s (Touring and EX-L models only) know the importance of disabling VCM with an aftermarket “muzzler “ device.
2006 Honda Odyssey (EX)
With those aftermarket wheels, it most likely came with PAX and the owner de-PAXed it.
2007 Odyssey EX-L
Yup, you should be good to go with the aftermarket wheels. I highly, highly doubt that the van has been muzzled. Very few people know that their car has a feature called VCM, and even fewer know what it does.
Reactions: thscott
Discussion Starter #9
Do I walk away if VCM isn't installed?
2007 Odyssey EX-L
Not necessarily. I would check out the rest of the car, but price the potential for VCM problems into the price. If your criteria for looking for a used car is that the VCM was muzzled... you're going to have a hell of a hard time looking IMO.
The Touring model has the VCM engine, so VCM is installed.
I think what you meant to ask is do you walk away if a VCM Muzzler is not installed.
The answer is no.
The VCM engine could be quite good and it will always benefit from adding a muzzler at this mileage.
If you do decide to buy it, your should definitely muzzle the VCM.
Who are you buying car from?
Do you have the Carfax for the vehicle, not perfect, but the best we can get for car history.
Remove spark plugs and look for oil fouling. You can also do a compression test while the plugs are removed.
Get a prepurchase inspection.
If you buy an EX or LX, you won't have any VCM issues.
The backup camera is crappy and only works well on cloudy days and at night.
Assume seller will come down at least 10% from the asking price. Use the inspection to bargain down the price.
1 - 12 of 12 Posts
