Hi again,
I'm having trouble installing our Graco SnugRide w/ Base. It is part of our new travel system, so I need it to work.
Basically, Honda, oddly enough, put the seat belt buckles forward of the seat crease. This seems like it would cause problems with quite a few seat bases. The manual specifically says that forward buckles should not be used...
Anyway - has anyone used this seat or a similar one w/ base in their Ody? The base has a seat belt path that is basically just loops on each end of the base. The belt goes in one side and apparently expects to go down into a buckle on the other. In my Ody the buckle side doesn't work right because the buckle part seems to get pulled into the base, and then the base wants to tilt on the buckle instead of being pulled down towards the seat.
I'm going to call Graco about a LATCH conversion Kit, but wanted to bounce this off ya'll as well.
Thanks for any advice!
Carlos
ody newbie
'01 MB EX two weeks old
Carlos
ody newbie
