Hi all,
I got a quite odd issue from my 03 (228kkm) today..
Approaching a stop sign, when the speed dropped bellow 20km/h, I felt very hard stroke from the front end and the whole vehicle body shuddered severely.. actually it felt like a car behind me hit my rear bumper quite hard (certainly there was no one at my back).
I dropped the gear selector to D2 just in case after she stopped completely and then she kept going like nothing had happened :confused:
Has been driven her for the entire day without any issue since then (not to count 1 slip from 3rd to 2nd which happens from time to time; I almost get used to it :mad: ). No engine light, no TSC light, no blinking 'D', nothing on the dash :confused:
The first thought came up to my mind was a dead trany. But it worked like a charm after (except for one slip).
The second thought is worn engine mounts. But I don't feel any regular shudder from her when idling on traffic lights.
What do you guys think?
Will appreciate any thought :)
The severe shift you described often precedes transmission failure. But until, and unless, it throws a code, there's not much you can do. How is the fluid level and condition?
Discussion Starter · #4 · (Edited)
Thanks guys!
I did hope it's not a trany but looks like quite likely it is :(
Anyway, I had ordered AB solenoids from Bernardy 3 days ago attempting to fix the slip. Will see if it'll make any difference to this crash sound too. Also will check mounts for leak.
PS: ATF was changed 2 weeks ago. Old one and current look and smell good. Level is also fine.
