1 - 20 of 24 Posts
I use the Sylvania Silverstar 9003/HB2 bulbs from Autozone because of their brightness. For some reason, one bulb burns out every six months. I replace it, then the other one burns out, etc. I use latex gloves when installing them.
Any clues why the burn out? Any other suggestions for bright bulbs comparable to Silverstars?
Clean them with ispropyl alcohol and a thick wad of not-lotion-enhanced kleenex, then don't touch the bulb at all.
There might be some nastiness being left on the bulb by the latex gloves.
I have used silverstars and they wouldn't last long at all. I just started buying bulbs off ebay...you can find them for $5-$10 a pair. I buy 2 or 3 sets, that way you have quite a few spares and it's still cheaper than 1 set of the silverstars. 5000k-5500k color temp is what I've found puts out the best light.
Just buy an HID kit for about the cost of a set of silverstars. It will last you a long time
Discussion Starter #5
I was just looking at these on eBay as well; like you said around $30.00, with bulbs.
I also tried the Silverstars and found they only lasted about 6 months. I switched back to OEMs from Honda. Those bulbs never burn out.
I gotta agree that the Honda OEM are great. we are at 8 years and counting.
How come the OEMs I took out of my ODy were made by Sylvania.?
Slyvania Bulbs
Same goes for me. Honda OEM bulb finally blew out after 7 years! I replaced one with XTRAVision from Sylvania, that bulb blew after only 7 months! Called OSRAM and they had me mail back the one bulb I did not use, they sent me a new pair. Not too happy about the life of these things and they really don't seem any brighter at night :( Stick with OEM stuff, we know that works.
Slyvania Bulbs
Because Sylvania has a large market share of the OEM bulbs. My Silverstars (not Ultra) last 2 years. So far I am pleased with replacing them every two years in exchange for the brighter road.
So why do the OEM sylvania's last long when their aftermarket version las half a year.?
because it burns hotter with the blue coat
I'm not sure about the science behind it, but I've been told that you should change both sides when replacing bulbs. Something to do with the efficiency of how the filaments burn. Replacing one side makes the older one burn harder/hotter, making it burn out quicker. Changing both at the same time, makes them burn evenly so they'll last longer. I used to have the same problem on an old car with one side burning out shortly after replacing the other side. After learning about replacing both sides at the same time, I've been finding that my bulbs are lasting longer.
Discussion Starter #15
I wanted brighter AND longer-lasting bulbs. The OEMs fail to meet the first part of the AND statement.
I bought a set last week so I'll try them. A customer at the Autozone casually mentioned this too.
No, I mean, when you buy a bulb from honda (considered OEM) they are made by Sylvania. So how come those last longer than the Sylvanias sold at walmart
just found this thread via search, i'm about to replace the passenger side bulb in my 2003 for the 4th time in 2 years, the driver side bulb is still original. I have been using sylvania replacement bulbs from my local auto parts shop and have been careful not to touch the glass. At least i'm not the only one seeing bulbs lasting only 6 months. The van only has 70k miles on it and is rarely used at night too.
Sylvania has many different models. The silverstars are designed to burn a little whiter and brighter, but they also burn out much quicker. Check the reviews on Amazon. That's just the price you pay for light output of the silverstars. The OEM sylvanias are designed to last a long time at the expense of possibly being not being as bright.
This may be a better approach to getting brighter headlights.
Daniel Stern Lighting Consultancy and Supply
Read carefully. Silver Stars are not brighter just whiter/bluer. No where on their packaging or advertising do they state that they produce more Lumens.
I bought a pair of Silver Stars figuring I'd give them a try. Replaced one original bulb and noticed a whiter/bluer less yellow light but not brighter. Then several weeks later replaced the other original bulb. First Silver Star died after 4-6 months. Second one died also around the same age. Bought OEM bulbs and have had no problems in over two years. I never touch the bulbs. I always hold them in a paper towel and wear surgical gloves.
1 - 20 of 24 Posts
