Hey all, was just wondering your thoughts on switching to LED lights from the halogen bulbs I have already installed in my car. Is the process just removing the Halogens and replacing with the LED bulb or is there more too it? What Lights do you have in your car and which lights could I buy right now that would work in my van? Thank you.
Always recommend doing a search for other threads before starting a new one.
Here is a thread on the subject for Gen3 vans.
I just converted the front end of my 05 Odyssey to all LEDS.
9006 for the regular headlights, 9005 for the high beams, 7440A for the front and rear turn signal.
The only issue I am having now is the DRL is not working when I drive and the DRL warning light is on.
The bulb works when I turn it on manually.
Does anyone here know which resistor / decoder I should buy to fix the DRL issue?
