1 - 7 of 7 Posts
We just got our Odyssey back from the body shop (I hit a deer on the front right) and the heated seats don't work. I suspect the shop didn't re-connect the wiring or something like that. I checked the fuse and it's ok. They did not remove the front door panels, but did disconnect the battery. I see no loose wires or anything obvious under the hood. I can take the van back to the shop, but wonder if there is an easy answer to this that I can do myself vs. being without the van for a day.
Fuse #78 (20A) in the Under-Hood Sub-fuse Box next to the battery.
Fuse #4 (7.5A) in the Driver's Under-Dash Fuse/Relay Box.
Otherwise, could be a faulty main switch, loose connection or bad ground.
Discussion Starter · #7 ·
We took it back to the body shop, who replaced a fuse. I thought I had checked that thoroughly, but guess not. Since my wife took it in, I'm not sure if it was under-hood or under-dash fuse.
1 - 7 of 7 Posts
