Very much advised you include your year and trim level in your signature or add it to your post so responders know which system you have. I assume you have the auto climate control? So when you adjust the temp the actuator door does not try to move? You replaced the door or the actuator? Did you use a new part, aftermarket or OEM, used part? Missing some info to be helpful.I have a small issue---My air conditioner is working but my heater is not working
I replaced the driver side flapper but it seems like it is not receiving power.
2006 EX-LVery much advised you include your year and trim level in your signature or add it to your post so responders know which system you have. I assume you have the auto climate control? So when you adjust the temp the actuator door does not try to move? You replaced the door or the actuator? Did you use a new part, aftermarket or OEM, used part? Missing some info to be helpful.
Correct sir!Could be heater core not allowing enough coolant through it to yield heat. Assume that you are getting air but it just isn’t hot?
I replaced the actuator, aftermarketVery much advised you include your year and trim level in your signature or add it to your post so responders know which system you have. I assume you have the auto climate control? So when you adjust the temp the actuator door does not try to move? You replaced the door or the actuator? Did you use a new part, aftermarket or OEM, used part? Missing some info to be helpful.
nd wallah I had H
No it doesntOne more test...does it get warmer if you drive at higher rpms like on the highway?
