1 - 9 of 9 Posts
My name is Roger Bishop and I own a 08 touring with blown engine due to VCM. What other non VCM drivetrains will fit my Ody?
Automotive parking light Wheel Tire Car Land vehicle
2007 Odyssey EX-L
Yours looks like an EX-L, not a Touring, to me.
Anyways, for the ECU not to throw any codes, you'll need to use another VCM-2 engine. Can't put another Honda J35 in there without replacing the ECU also, and maybe other stuff as well. See if you can source a low mileage junkyard one, and then muzzle it to prevent future problems. That's the route I would take. Or maybe a rebuilt engine at the right price.
My name is Roger Bishop and I own a 08 touring with blown engine due to VCM. What other non VCM drivetrains will fit my Ody? View attachment 163731 View attachment 163731
Well thank you! I plan to do an entire non VCM swap including pcm and harness. Was looking into the Pilot drive train, because I would love and of four wheel drive. It got stuck in a flat drive lol
Why do you say it's blown? Did the Honda 'stealership' want to sell you a 'ring job'? Disabling or 'muzzling' the VCM will often undo the issues with the rings and oil consumption. Have you read the The VCM Megathread - what is VCM, does my vehicle have... thread?
How would you do the drivetrain to the rear wheels?! o_O
Reactions: WiiMaster
I am going to research that. I have seen v8's in them may need to fabricate. Fortunately I have a dear friend who is a master fabricator. I lost a cylinder when the rings dropped. We compression tested it, and it smokes like a freight train. 275 k on it. I bought it used so got my money's worth. I like to hot rod things lol.
When using "Reply" please put your answer after the [/qoute] directive! :unsure: It's a mess trying to find your answer!
Well, it sounds like it's past the point where muzzling would undo the problem. Good luck on retrofitting it to AWD!
Discussion Starter · #7 ·
Thanks all. Anything is possible, now, the real question is, is it probable LOL!! I may end up parting her out or going the rebuilt engine trans route.
Sourcing from an '08-'10 EX-L or Touring would be the easiest replacement- and muzzle it!
Reactions: rogerb740
2006 Honda Odyssey (EX)
If you're okay with a constant CEL (probably wouldn't pass emissions inspection if you have that in your area) then you can definitely do a non-VCM swap. But no way to do it without a constant CEL.
I would muzzle first, maybe run some Techron and/or do a cylinder soak as well before condemning the engine. Disabling VCM is way cheaper so it's worth a shot.
1 - 9 of 9 Posts
