A posting form Hip in a posting from March, 2001, referred to a procedure in the Helm Manual to erase the DTS memory to reset the SRS light.
I energized the ignition while installing my subwoofer to test it out before putting everything back together. This caused an error signal to be generated in the SRS diagnostic system because I had the side airbag connector disconnected.
Can someone look up and post the procedure on resetting the DTS relay for me. THANKS!
Thanks, the link you quote is the same one I referred to.
Hip says: "Went through the SRS troubleshooting part in my 99 manual (starting on page 23-27) and came across this section titled "Erasing the DTC Memory."Honda mentions using a special service connector (07PAZ-0010100)which is nothing more than a 2 pin OEM female connector. Since I save EVERYTHING, I just happened to have one from a wire harness I saved when I replaced the turn signal/wiper control on the 89 Accord several years ago. After soldering the 2 wires together as per the illustration and following its convoluted directions, all is well."
What I am hoping someone will post for me is the "convoluted directions" from the Helms manual on how to do it.
Thanks for your suggestion.
Still hoping for some help!
