savage,
it is odd that two sensors would go at same time... After looking at the Schematics for parking assist I see that the two centers do share a common leg..so if that wire is cut or corroded it would explain why two would be out.. and the Sensor CPU (Left under Dash)would report fault for this as the circuit would be open and the controller would think both are not there.. Common wire is Black with red and is pin 13 on the controller... (BS-E).
also since you just purchased , look for signs that maybe a trailer hitch was installed and they removed.. maybe breaking or cutting this circuit...stranger things have been known.
And to your original though of multiple fuses, there is only one fuse for the whole parking controller unit... Fuse 21 7.5A
