You finally bought the woox, didn't you. Are you trying to put the woox in the dash?
I was trying to look for Chuck's pics but couldn't find it. I think he closed it down when he sold the Ody.
To take it out, you have to pull the dash plate out held by clips. (I wish I had the pictures.) Bring the shifter down to the lowest gear (I think it's D4) and carefully start from left hand most tip of the plate. You'll have to get your fingers in between the plate and the dash. Carefully work your way around pulling it one clip at a time. There are 9 clips altogether - 5 on top, 1 on the side and 4 at the bottom. See if you can pull up the instructions I sent you on the Kelton sub. You'll find the locations of the clips there.
Once the face plate is removed, the radio is held by 4 bolts, 2 on each side.
Call me at work if you're still having problems.
