1 - 2 of 2 Posts
Well, I fixed one sliding door problem last year thanks to the posts on here, now I have a different issue with the pass side door. After much searching, I didn't find anything like the following issue to reference.
The door will not open from the inside handle, in either manual or power mode. It works fine from both the dash switch and the outside handle, and it will close from the inside handle if its already open.
I've traced the problem to the mechanism with the orange arrow pointing to it in the attached pic. If all I had to do was replace it, all would be good, but I can't find it on the exploded drawings on either Majestic Honda's site or South Bay Honda's site.
Anyone have any ideas? A name for the mechanism, or what sub-assembly to look under? I've tried all the sliding door sub assemblies.
Discussion Starter · #2 ·
In case someone has the same trouble that I did, the part in question is the Latch Assembly, part 72610-SHJ-A21 for the passenger side. It is listed under "SLIDE DOOR LOCKS-OUTER HANDLE", and is pretty hard to recognize while it is still in the car if you are looking at the exploded drawings!
1 - 2 of 2 Posts
