Hi! Looking for some help here. I'm in the middle of changing out my timing belt on my 2008 Odyssey EX-L w/194k miles (It's ~19 degF in Michigan today). 1st timing belt I've done personally, but this will be vehicle's 3rd.
I turned the crank to get both crankshafts in the correct position before starting removal of the belt; and after I started removing the timing belt and one of the pulleys I noticed that the rear camshaft was no longer in the correct position, but the crank and front camshaft both still were! I'm not sure how this happened; I don't know how the rear one could have turned without turning the others since they were all connected via the timing belt...
What do I need to do to make sure the rear camshaft is set properly, now that it's off?
See the pictures below for reference:
Picture of the rear camshaft (the white marks I made are where it was aligned prior to [blank] happening; I still don't know what that blank was:
Picture of the front camshaft (the white dots I made are aligned):
Picture of the crank (still aligned):
Overview of the work (damage?) completed so far:
Also, the rubber in the side motor mount I removed is basically shredded. Any issues with just replacing that mount and not the others? I thought rule of thumb is to replace them together when doing it, so looking for some insight here too.
Thanks all!
Thanks all!
