All,
07' Ody EX with 75K. Never had an issue until now. Wife was pulling in the sub today and a CEL came on. The traction control VSA triangle and VSA light were on along with D flashing on the trans. It would not go past 3K.
After each restart it takes a random amount of time (within minutes though) for the VSA and blinking D to come on. Prior to that it drives normal with just the CEL.
I found this:
TSB # 09-042 Damaged Camshaft Position Sensor (CMP) Causes the MIL to Come On With DTC P0344
Applies To: 2005–07 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A09-042.PDF
What to do next?
Autozone does not have the sensor in stock and the dealer is closed. I'm ticked that we are out of warranty.
Can I access it without yanking the valve cover?
Do I have any ground to stand on since this was a known problem with the TSB?
I found this:
What to do next?
