1 - 9 of 9 Posts
Hello all,
I really need some help with this one.
The roof is leaking into the front overhead lights between the drivers and passenger seats.
How do I fix this?:huh:
Super Moderator
Are you sure its the roof and not condensation accumulating over there? Do you see any holes in the roof? The roof is sealed from the factory and I believe its one piece.
It is definately rain water. Normally the Odyssey sits in the garage, but it had to sit out last night and there were heavy storms.
Did you have the windshield replaced recently? Faulty seal around the windshield could cause a water leak. Other areas to seal are the roof rails and any rivets/bolts under the headliner.
Discussion Starter #5
Windshield is original. How do I take down the head liner and how to I reinstall?
Super Moderator
Sorry didn't have coffee yet this morning. I misread your post and believed you were saying the leak was in the passenger cabin in the middle of the van and not the front. I am with NDNV. The leak has to be in the windshield seal if you are getting the leak on that front overhead light.
2013 Odyssey EX-L RES
Same thing was happening with my Ody a while back. It was the windshield seal.
How did you have this fixed?
Had the gasket around the window replaced. Apparently it goes from top center, all the way around and meets again at top center. There is an overlap there, it is not solid. As it ages, it shrinks and pulls apart creating a small leak.
1 - 9 of 9 Posts
