The cast bolt (the 14mm bolt that is to be used with a serpentine belt tool to push on and remove tension) of my NEW Gatees tensioner became stripped as I was trying to install a new belt. Are there any recommendations on what I can do to release the tension ? I could never actually fit a bolt in the tight spot and used a serpentine belt tool with a crows foot attachment... big mistake!
I am nearly done replacing the alternator, belt and tensioner, replacing with all new parts. I had installed a new tensioner and alternator and am at the point of installing a new belt.
I used a serpentine belt tool with a 14mm rounded crows foot to release the tension several times as I worked the belt on. I was a one-man show in doing this so I had to do this several times. Anyhow, the cast bolt is deformed on two edges and won't work with the crows foot, and can't get a socket on it due to the tight space.
Any thoughts are appreciated.
I always use the 14mm combination wrench /box end and a 15mm combination wrench/ open end locked together to push that tensioner up. If the bolt on the tensioner has no more corners and it won't bite, I guess you can try locking pliers. Or just change the tensioner altogether. Its held by 2 10mm bolts on both ends and an 8mm in the middle of the pulley. The dip stick holder needs to come off - 10mm bolt.
Got it to work with a smorgasbord of box end wrenches and such as you suggested.
One more thing now - The PS pump is making a loud noise. I removed the ps hose from the reservoir to the pump @ the pump connection while doing all this so I could get some room in there. I put it all back together and started the car and it's making this loud somewhat grinding noise. I added a bit of the right PS fluid but still no avail. I turned the wheels left and right and it works, but that noise is telling me of an obvious problem. I haven't actually driven it away yet.
What to do about the PS pump noise ? Do I have to "bleed" it ?
It could be the rubber O ring needs replacing. Its known to make noise when old. One thats on the pump end. Lots of post on it.
It could also be the return hose. They get hard with time and so won't seal after being disturbed.
Like the o-ring, it's under negative pressure. So when it leaks, it lets air into the fluid. i.e. there's no visible fluid leak to indicate the problem.
