Hi, I'm new here. Wondering if anyone can help.
My husband took my van to work the other day and it drover perfectly fine. When he left work about 12 hours later the van would turn over but wouldnt start? All the cousin light would come like normal. When we wou.d go to turn the van off that green key light would flash about 5 times and then stop.
I believe it is called the immobilized system indicator light.
Or when we try to start it the shifter is in park but the shifter says it's in drive and then switches to park.
Any ideas? I want my car back
Well the green key icon is for the immobilizer and should flash 5 times after the ignition is turned off so that is normal.
I know there is a gear selector switch that is wired, I believe, to only allow the van to start in park or neutral. If the van thinks it is in drive because the switch is bad then that may be causing your problem. That is my only thought.
So we rented the computer and a code came up po740. Torque converter circuit. Anyone have any knowledge on this please?
