Spoiler Gasket Repair Tip
I fixed this on my 99 Ody using 3M Weather Stripping Adhesive (about $4 at auto store). Its black and the stickiest stuff you'll ever see. So far its holding great and should work better than original double stick tape that was used by Honda.
- Remove Tailgate interior upper trim to expose 4 nuts that hold on the spoiler.
- Remove the nuts. There is also a snap in the middle to release. I could not get it off thru the small hole provided, so I left it in and wedged a piece of 1.5" wood between the spoiler and the glass so I could work.
- Remove all the rubber gaskets, noting where they are. Remove the adhesive tape, clean them with lighter fluid and roughen with sandpaper.
- Remove the adhesive tape from the spoiler, clean with lighter fluid and roughen with sandpaper.
- Apply the new adhesive per directions and reassemble.
They are not kidding on the adhesive package: Don't get this on your hands. Wear rubber gloves. Lacquer thinner works well to remove it.
I believe the purpose of the gasket is to prevent the spoiler slapping the glass when closing the tailgate and to prevent vibration against the glass while driving, so i did not want to just remove it.
1999 Ody, 114,000 miles
Update: Sep 2010, fix is still holding. Now at 150,000 miles and 4th tranny.
