Hi everyone, 1st time joining and posting. I have a 2018 EXL with Nav purchased new. At 41k while stepping on the gas pedal I would hear a loud/high throttle sound(almost like a motorcycle engine) with no engine light on. Thinking it might be the transmission issue, took it to the dealer. Dealer diagnosed it with a high pressure pump failure. Relieved it wasn't the transmission. Service advisor said the it will be covered under the powertrain warranty but another part that was needed, "fuel joint pipe set" will not be covered. So fine, I had to pay $500 for parts/labor and taxes. Picked up the van on Wednesday and over the weekend, this time the engine light came on with message emissions system problem, i stopped by autozone and borrowed their code reader and they told me it's P0456-Evap system small leak.
Is this code related to the fuel pump replacement? It can't be coincidence that the light is on after a repair.
And after doing some research, shouldnt the high pressure fuel pump and the related fuel joint pipe set be covered under the same powertrain warranty? What are my chances of getting the $500 dollars back from the dealer?
Any input or advice is appreciated!
I've made an appt to go back to the dealer regarding the code.
