Status
Not open for further replies.
1 - 1 of 1 Posts
Super Moderator
Discussion Starter #1 (Edited by Moderator)
This Honda Job Aid provides information on how to perform an engine compression test and a cylinder leakage test on Honda V6 and L4 engines.
Always refer to the service manual for the exact specs for minimum compression pressure and maximum variation for your Odyssey year and trim level.
If you are not using the Honda MVCI and HDS, then you will need to manually disable the fuel injectors and ignition system, as needed. This can be done by removing the applicable fuse(s) or relay(s).
Engine Compression Test and Cylinder Leakage Test - V6 Engines
http://www.urvi.net/forumfiles/SN/AJA45445.PDF
http://techinfo.honda.com/rjanisis/pubs/FF/AJA45445.PDF
Engine Compression Test and Cylinder Leakage Test - L4 Engines
http://www.urvi.net/forumfiles/SN/AJA45446.PDF
http://techinfo.honda.com/rjanisis/pubs/FF/AJA45446.PDF
Honda Tech2Tech Videos on Compression Testing and Cylinder Leak-Down Testing can be found here and below:
http://www.odyclub.com/forums/9-problems-concerns/91553-honda-tech2tech-videos-service-technicians.html#post714972
Engine Troubleshooting: Step 1: Compression Testing
http://tor.in.honda.com/rjanisis/pubs/web/ml.rjanisis_flash.htm?file=amv101202.flv
http://techinfo.honda.com/rjanisis/pubs/web/ml.rjanisis_flash.htm?file=amv101202.flv
Engine Troubleshooting: Step 2: Cylinder Leak-Down Testing
http://tor.in.honda.com/rjanisis/pubs/web/ml.rjanisis_flash.htm?file=amv101203.flv
http://techinfo.honda.com/rjanisis/pubs/web/ml.rjanisis_flash.htm?file=amv101203.flv
Additional information on Honda Engine Firing Orders, Cylinder Numbering Layout, and Engine Rotation Direction can be found here:
http://www.odyclub.com/forums/14-periodic-maintenance/156155-honda-engine-firing-orders-cylinder-numbering-layout-engine-rotation-direction.html#post735420
1 - 1 of 1 Posts
Status
