Hi Folks,
I've got a problem. I bought the factory Honda alarm system from Handa Accessories. After going over the directions while looking over the car, I dove in and did the installation and had absolutely no problems as far as I could tell. Once things were done, I felt like I had a little trouble programming the remotes. I discovered an error I had made in the process and things seemed to go a bit better. The only thing is, at the end of the process, you push the lock button and the door locks are supposed to cycle and the alarm indicator light is supposed to light for one second for each remote you program. This part didn't happen. All it did was arm the system so I'm not totally sure what's going on.
The alarm system is also not responding completely like the directions state. For instance, it is supposed to unlock the drivers door on the first push of the unlock button. This does not happen. The interior light activates like they're supposed to but the drivers door does not unlock. On the second push of the unlock button, all doors unlock. If this were the worst of it, I could live with it but I'd really like the system to perform as the directions state with the drivers door unlocking on it's own and the rest unlocking only when I punch the button the second time.
The worst of it is that with everything hooked up, my cruise control will not operate. The cruise control on/off switch light on the dash is active indicating there is power to the cruise control but system will not set. It's like the set and resume buttons on the steering wheel are disconnected. I triple and quadruple checked all the connections and could find nothing wrong. Finally, I disconnected the alarm wiring harness from the Odyssey's and plugged all the cars connectors back into their original positions and the cruise control works fine. I reconnected the alarm per the directions and no cruise. Now mind you, there aren't "that" many (7) connectors to play with that interface with the Ody's wiring loom directly and all of them are unique and keyed so that there is no way you can plug into an incorrect connection or connect a plug backwards. It's simply not that complicated.
I gave Handa Accessories a call and explained the symptoms and they were unsure as to the problem. They did, to their credit, agree to send me a new system (wiring loom and alarm brain) in the unlikely event that I got a defective one. I have now removed the first system and installed the new one and, to my disappointment, have the same problem. The second alarm behaves exactly as the first and when it's plugged in, my cruise control is totally unoperable.
Can any of you good folks offer any insight into what's going on here? It's like Honda made some minute change in the 2001 models wiring looms and the alarm isn't compatable any more. I'd greatly appreciate any input you care to offer.
Thanks & Drive Safe,
Steve
Steve
