Status
Not open for further replies.
1 - 20 of 189 Posts
Very nice!
Thank you!
THANKS A BUNCH!!!!!!!
Thanks. I've got a friend who had an awful time with vibrations his 06 Pilot. I'm emailing the pdf's to him.
Discussion Starter · #12 · (Edited)
March 2008: http://www.urvi.net/forumfiles/SN/A080300.pdf
No Cruise Control? Check for Aftermarket LED Brake Light Bulbs
Now Available: Extreme Cold Weather Antifreeze/Coolant Type 2
MIL On With DTC P0171 or P0172? Check for an Aftermarket Air Intake
MIL on With DTC P0111, P0128, P2183, or P2185? Check ECT Sensor 2
VSA Activation Indicator On After VSA Modulator-Control Unit R&R
Stained Paint Under the Wrap Guard? It’s Just Trapped Moisture
CVT Slips, Slams Into Gear, or Flares on Acceleration
MIL On With DTC P0607? Check Connector C102
Rear Camera Image Looks Dark or Blurry After Installation
April 2008: http://www.urvi.net/forumfiles/SN/A080400.pdf
Automatic Lighting and Automatic Lighting Off Are Different Features
Installing Wrong Replacement ECM Can Cause DTC P0443
Can’t Turn Off the VSA? Check If the TPMS Indicator Is On
Replacing Flywheel? Transfer Sensor Ring and Torque to Spec
Got DTC U0121? Try Swapping the ABS Modulator-Control Unit
Quick Start Guide Error
Alert: Rear Window Wiper Operation
Power Sliding Door Beeps Three Times, Sets DTCs, Won’t Work
Leaking Head Cover Gasket May Just Be a Residual Oil Trail
HFL Troubleshooting: Checking Cell Phone Compatibility
Michelin PAX System Runflat Gel 3: Read All About It
Remove Protective Covers Carefully to Avoid Seat Cover Burn Marks
New Software for HDS: Version 2.013.017
as always thanks for keeping us updated...
Has anyone found the Service bulletins in this file structure?
Discussion Starter · #17 · (Edited)
May 2008: http://www.urvi.net/forumfiles/SN/A080500.pdf
Use Throttle Depressor Tool for A/C System Performance Test
New Software for HDS: Version 2.014.008
Treat the HDS Like a Computer to Help Avoid Lock-Ups
Block Halves Leak? Check the Sealing Bolt or Rear Main Oil Seal
Ceiling Light Rattles or Buzzes While Driving
M/T Intermittently Pops out of 1st Gear
Front Passenger’s Seat Belt Frequently Locks Up
HFL Troubleshooting: Dealing With Pairing Problems
Troubleshooting DTC P0962, P0966, or P0970? Try This Simple Outline
You mean May 2008. My how time flies. :D
With regard to this newsletter:
If only the Bluetooth did apply to all 08 Odysseys with Navigation. Sadly it really only applies to 08 Tourings.....
Discussion Starter · #20 ·
I have no idea where that "5" came from? Correction made.
1 - 20 of 189 Posts
Status
