Those are the key words!!!!!sale price
If the warranty covers an item for X amount of miles and that item quits working properly during that mileage, there is no wear and tear excuse in my book."Sorry, Charlie. It's normal wear and tear, not covered by warranty. We can replace the suspension components for a sale price of $2500, though."
Squeaks in suspension happen for a lack of lubrication in the shock absorber, normally because it is leaking.Squeaks are not covered by any warranty, original or certified. Failed parts are.
Squeaks can happen for plenty of reasons. His point is that the squeak itself is not covered by any warranty. A part failure causing the squeak may be covered, but not the squeak directly.Squeaks in suspension happen for a lack of lubrication in the shock absorber, normally because it is leaking.
A leaking shock absorber is covered by a standard warranty, and mine specifically states that it does.
Not sure where you are getting that info
not sure where you're getting yours, warranty guy...Not sure where you are getting that info
Im getting mine from the warranty booklet that specifically says that it is covered.not sure where you're getting yours, warranty guy...
Thanks for the info!Shocks are easy enough check. It is very unlikely that they certified your car with leaking shocks. They would have to be very dishonest to do that. If you have a Jack and can take wheels off you can check yourself. Other than that squeaks could be very hard to identify. It is annoying but typically doesn’t affect drivability.
Might be!That third issue is usually a sign of worn out motor mounts.
The squeak is not covered as I mentioned but if it from a failed part, like a leaking shock absorber it could be. The warranty link you mentioned also specifically excludes rattles:Squeaks in suspension happen for a lack of lubrication in the shock absorber, normally because it is leaking.
