Hi there,
I have Honda odessy 2010, all of the sudden horn and cruise control stopped working, but the alarm horn working fine. I checked the fuse number 13 but it is fine. Could any one give me the solution for my problem. Thanks in advance
Have you heard any grinding sounds from the steering column? If so, its possible you have a bad 'clock spring' which is the wiring harness system for all buttons on the steering wheel. I had same problem on a Dodge, first lost horn and cruise operations then finally SRS light comes on because it could no longer communicate with the air bag on the steering wheel.
Thanks for replay, I haven't heard. even no check light on the dashboard right now. before the problem happened, I remember there was a sign of exclamation mark in a circle, I was thinking it is for tire pressure, but I ended up with this issue.
