If you are referring to the horn actuation, it is the same as that of on the '02 Acura TL - which is pretty much the whole center pad on the steering hub. Instead of in the middle of that center pad in the prior years.
The horns are located behind the front bumper underneath each headlamp. If you're planning on removing them, make sure you give yourself time. I had "fun" (yeah right!) doing just that.Actually, I ended up just tapping into the wires and not going through the hardship of removing half of the bumper.<font face="Verdana, Arial" size="2">Originally posted by bmorison:
Does anyone know the location of the horn on the odyssey, 2001 if year makes a difference. ill cut down on my search time.
Thanks,
Bob
Which Hella horns did you get ? The Hella reds ? Those are good horns. I installed a pair of Fiamm air horns. This was a tough one as there's not much space to locate the trumpets.The Hellas will be easier since they're flat.<font face="Verdana, Arial" size="2">Originally posted by bmorison:
Thanks, so there horns, not horn, good as I have to parts to the hella replacements. Loooks like a fun weekend ahead !
<font face="Verdana, Arial" size="2">Originally posted by hachiroku:
