I know that you need to go through the transmission dipstick to fill, but what sort of a funnel/hose do you use to do that? I can't seem to find anything suitable.
There is a big giant fill hole on top of the transmission. Requires a bit of force to break the bolt loose but its the right way to fill it.
But that giant fill hole gets all hard-to-use after the recall work is done, assuming you had it done.
The way I do fluid addition to the dipstick tube is I have a short length of clear tubing(vinyl, I think) which fits snugly around the OUTSIDE of the dipstick tube, and also around the snout of a plastic funnel several inches away. With the right sized funnel and tube, it can be leaned against other stuff nearby and you don't even need to hold it in place.
