1 - 6 of 6 Posts
I want to program the door locks to automatically unlock when I shift into park as others have suggested is possible. When I look at page 101 in my manual, it tells to use some buttons on the right side of the steering wheel and even has a drawing to show where they are at. The only problem is, there are no buttons where the manual says they should be! I'm talking about an up arrow (with a little i on it) a down arrow, and an "sel/reset" button. In the diagram, they're on the right of the steering wheel just below the cruise control buttons. The manual doesn't say to do it differently on a particular model (I have 2012 EX-L with NAV). Anyone have any ideas, or should I drive over to the dealer tomorrow and ask?
Those buttons you are referring to are only available on Touring Models and are used to control the multi-information display (MID). Since you have an EX-L model, you must do things manually. For you to change your door lock and unlock behavior, you need to refer to pages 117-119 of the 2012 owners manual.
Incidently, you can also look at these existing threads:
http://www.odyclub.com/forums/54-2011-odyssey/152184-2012-exl-auto-door-lock.html
http://www.odyclub.com/forums/54-20...-automatic-door-locks-front-park-sensors.html
http://www.odyclub.com/forums/54-2011-odyssey/147955-program-ex-l-door-locks.html
Is these thread work for EX model as well?
Thank
In pages 117-119 of the 2012 Owner's Manual, the instructions state that they are for models without the multi-informational display, so technically they should work on LX, EX and EX-L models. Give them a try and let us know if they work for you.
1 - 6 of 6 Posts
