I'm working on replacing the original rear shocks on my 2003 with 196K miles driven in Illinois. Multiple attempts with a 365 ft-lb impact wrench was not able to loosen the top bolt on the shocks after 24+ hours soaking with penetrating oil. These bolts are extremely rusted. I'm thinking about getting an impact wrench that can apply 1,200 ft-lbs.
What guidance can anyone offer on the torque I'm likely to need to loosen these top bolts?
Is there a max torque that I'd want to use .. beyond which I'd be likely to damage the bolt or threads?
Once these bolts are out, am I likely to have significant difficulty replacing these bolts, such that i'd be best to buy new bolts for reassembly?
Thank you!
if the bolts are toast replace them, if just rusty and still have lots of good thread, wirewheel on the bench grinder will do the job.
if they are seized, try some heat also try working them on and off slightly to break the seize.
If you dont have torches the map-pro gas (yellow can) should give you enough heat.
heat the bolt and area not the shock! the rubber bushing will burn, so have water nearby.
My first choice would be to sawzall the bottom of the shock off surrounding the bolt / bushing, and work at the bolt when with the shock out of the way.
had to do this on my kids car, which was a pin / nut setup, 10 years of salt belt exposure seized solid to the sleeve on the shock.
make sure you get anti seize on the replacement bolts, to avoid this headache next time.
good luck!
Bought a used 2003 from a friend, needed new rear shocks. I broke the rear bolt off on the change when removing the nut. I had to cut the rest out. Replaced with a new grade 8 bolt and nut when I put on the new shock. No ig deal except for the initial removal. As long the the bracket is good, you will be fine.
Discussion Starter #4
Thanks for the input @cahaak & @Ticket Team but it doesn't answer my question. I'm not prepared to get into cutting rusted parts off the van. I'm prepared to up the torque with a bigger impact wrench.
If cutting is going to be required because I can't apply sufficient torque or because I apply too much torque and break it .. I will take it to a shop to deal with that.
So I want to know from the experience of anyone who's done this job on an odyssey, what torque was required? what torque was too much are caused breakage? .. or perhaps confirm that no amount of torque is going to get the rusted bolt out and I should pay someone to cut it. I'm not really interested in getting my torch out on this one either.
So the decision is me and 1,200 ft-lb impact wrench .. or paying the shop to do the work.
What say you?
What say you?
cutting will allow you better access to the seized bolt, which is most likely fused inside the sleeve for the shock.
if you go gorilla on a seized bolt with an impact it can go one of two ways, bolt comes off or the bolt snaps.
if you're looking for assurances or someone to blame if it breaks, you came to the wrong place.
The question you're asking, on the maximum torque a seized rusted bolt can handle before breaking is a hard one to answer.
feel free to continue waiting on that answer, or follow the above info or pay someone with the proper equipment to do it right.
