How often should I change my timing belt? 2012 Odyssey. What else should I do to it while it's at the shop?
537 Views 11 Replies 6 Participants Last post by  adr5
Van has 160XXX miles on it now. I did timing belt, trans drain and fill, serpentine belt, fuel injection services as well as steering and brake systems. Work was done at 94000 miles.
1 - 12 of 12 Posts
What did you find when you read the timing belt mega thread?
Reactions: 3
How many years has it been since the timing belt was changed last. Recommended time interval 7 years.
Done almost 2 years ago but I drive 50K plus miles a year on it.
When I copied your post subject into the search feature and used it, there was a result with the subject
The timing belt mega thread - why change it, service intervals, parts to change, recommended parts to use, and more
It seemed like the type of post that would have many of the answers you're looking for, all put together in one place.
Reactions: 2
What does it say in the owner's manual? :)
By time, you have 5 years to go.
By mileage, 105K service less 66K driven = 39K to go.
BTW, the original coolant should be changed at 10 years. If not already done, it's overdue.
Timing belts will about 100k miles. If you did it at 94k, then the next time would be at 194k. You should be doing trans drain and fill about every 30k miles. So you should consider doing that .
1 - 12 of 12 Posts
