3rd row roof vent by the passenger side has the vent flaps all askew. Some turn left, some are closed, some turn right.
Looks like there is some sort of thin bar that the vent flaps attach to.
I need to try and fix this. Is there a way to remove the vent mechanism and get at the flaps from the other side (so I can fix whatever is broken)?
Thanks
Dan
Discussion Starter · #2 ·
Bump for anyone?
Super Moderator
Got Pix?
Will post later tonite.
Super Moderator
You should be able to pop the vent out and replace it with a new one. I think the plastic bar that holds the flaps is all one piece (flaps and the bar) and it might have broken allowing the flaps to go either way but I am not sure as I have closely looked at the vents. All the rear ones should be the same so you should be able to compare one with the other to see if you spot any broken plastic.
