Hello trying to find out how to " jump the scs with the hds" so I can check evap purge line and circuit. original post:
Hello,
Have 2006 odyssey with code p0443, doing the trouble shooting in 2005-2006 service manual have no vacuum, but could get it if I power the purge valve with battery directly.
in 18 in manual, it states jump the scs with the hds- if I do not do this can I still disconnect the pcm to check for wire continuity to valve?
I do not have the 33 OHMS as the book states, but I have about 30 at room temp.
Any ideas?
Thanks
Andrew
Hello,
Any ideas?
Thanks
Andrew
