1 - 9 of 9 Posts
Many folks use this backyard solution: determine the direction of engine rotation and put a flex handle (breaker bar) and socket onto the crankshaft bolt in such a way that the bar will contact something solid, such as the subframe or the garage floor (you may have to put a "cheater, such as a piece of pipe to reach the floor). Be sure to use a six-point socket to prevent stripping or breakage. When this is set up, bump the starter and the bolt will be loosened. Yes, I have used this method. Of course, if you can find a proper tool to hold the pulley, go for it.
Good luck, Jerry O.
I neglected to mention in the above post that you must disable the ignition before you energize the starter so that the engine will not start.
Jerry O.
I'm in the middle of a water pump/timing belt change and I would like to inspect and possibly replace the camshaft seals. Is there a good way to hold the pulleys so the bolt can be loosened?
Check this.
2006 Pilot camshaft and crankshaft seal r/p - Honda Pilot - Honda Pilot Forums
http://www.extremeprelude.com/info/pics/Removecamgear1.jpg
"You just stick a ratchet extension through the spokes of the cam gear and then toruqe the bolt off. Just cover the end of the extension with a towel or rag so it doesn't mark up the cylinder head."
"There is a cover behind the gears that has 2 - 12mm bolts. You can place a socket and ratchet to hold it still while you muscle the bolt loose. I used a 18" - 1/2 - breaker."
baseball, I've often wondered how to do this. Thank you.
I saved that pic from the Prelude forum.
Discussion Starter #7
Check this.
From what I could tell, that won't work on ours as the cam gears do not extend above the head. I bought one of these: Pulley Spinning Tool but ended up breaking the cam pulley as it didn't fit quite right:nothappy:. Now I need a new pulley. It looks like one of these is the correct solution to hold the gear:
http://www.amazon.com/OTC-4754-Universal-Pulley-Holder/dp/B000Q8GVPY/ref=cm_cr_pr_sims_t
Amazon.com: Customer Reviews: OTC 6613 Variable Pin Spanner Wrench
Whatever you do, don't use a chain vice grip to hold the cam sprocket / pulley. It will mar the gear, it's soft.
1 - 9 of 9 Posts
