I've got the condensor coil loose and ready to lift out of the van. I have a clearance issue with the headlights, though. The condensor coil makes contact with both inside edges of the headlights. I thought about removing a headlight, but can't see much access to the mounting hardware. Has anyone else ran into this problem?:huh:
Did you remove the radiator upper brackets and front grille?
I removed the radiator brackets. I'm not sure how to remove the front grill. I've got the radiator loose and free. I'm just shy about half an inch of the condensor coil clearing the headlights.
Glanced at the shop manual. The condenser should lift out without disturbing the headlights. But you have to remove the grill. This is easy but requires some forearm flexibility. Remove the pins along the bottom of the grill.
