Fixed!
Today I replaced the condenser fan...what a PITA...initially. According to autozones web site ..to remove the condensor fan it was necessarry to remove the radistor fan first..This entailed removing the battery and its casing , undo the many harnesses out of the way , the central pillar from the radiator mount and sliding the fan units out by way of the space created by removing the battery..what a pain that was. Dont do it that way !!! I almost ruined my radiator !! I got the radiator fan out this way but when I tried to do the condenser fan and since the shroud was all metal I began to think twice for a better way...soooo here is what I did.....remove the bumper and headlight assemblies,undo the upper radiator hose..now the radiator and condenser can be tilted forward to facilitate the removal of both fans ! There are four mounting tabs for the condenser fan , two upper and two lower..remove the upper bolts but only slcken the lower bolts as the tabls are slit. All bolts were 10mm. The radiator fan (drivers side) has two upper bolts but tabs that fit into a recess at the bottom of the radiator. I did lose some anti freeze ..perhaps half quart. Everything is working fine now..what a day...cheers
