1 - 10 of 10 Posts
2019 EX-L with Nav/Res, Pacific Pewter
After removing fog light trim, can you directly get access to replace the fog light assembly?
I looked inside the wheel well & i see no easy way to remove fog light assembly alone since its combined with turn signal.
Or, is the only way to remove the bumper & remove the fog light/turn signal?
Thanks, any videos or diagrams or instructions would be helpful.
Its, but, i would like to replace the factory halogen light with an led assembly (not just led bulb).
Thanks for your response though.
Any insight into how to replace would be helpful.
Honestly if I had to do it again - I'd definitely remove the bumper. You can remove the trim through the wheel well, then move it around and remove the bolts holding the fog light from the opening created on the front but it's a pain and takes longer that way. I'd say it took me 30+ minutes per side. It would be way quicker with the bumper removed. Just remove the whole bracket, swap out and you're done! 👍🏻
155456
Discussion Starter #6
Ah, so, you can't remove the for light trim from the front, but, have to remove a bolt through the wheel well?
Yes, screws and clips that are accessible from the back. Then you have to remove the bolts holding the fog light from the front, then feed the fog light back through the wheel well iirc. Like I said, it's way easier with the bumper off. 🙂
Discussion Starter #9 (Edited)
I wanted to replace with Diode Dynamics SS3 led fog kit...
Though its marketed for Civic & Pilot, do you think this will work for Odyssey?
When i look on Amazon CarParts360 sell similar oem style fog light for Honda & Acura.
Dont want to go through the whole trouble if it maynt fit.
Thanks for everyones response.
Discussion Starter #10
Plus, as a non expert, would prefer to not remove bumper to get this done.
1 - 10 of 10 Posts
