1 - 1 of 1 Posts
My van has ~205,000 miles on it. Oil leak from the rear valve cover gasket.
Since I am in there, I figured I might was check the valve clearances.
But I have never done that before and reading the manual it seems like it is a bit more work as you have to TDC each cylinder and them plus doing the air pressure check...
Now I am second guessing if I should bother or just replace the gaskets and fix the leak.
When it is cold, it the engine seems a little noisy. Not so bad once it's warm.
1 - 1 of 1 Posts
