1. honda odysey 2012 fault 12 anti lock brake traction vehicle (Fault 12)
/ABS/TCS/VSA/
2. Battery voltage High - 62_1 - Permanent DTC
3. Battery Voltage Low - 61_1 - Permanent DTC
4. Body Electrical Integrated Control System - (Fault 11)
5. Rear comunication Failure - Permanent DTC B2965
Can anyone help me on what the codes means and how to fix it? I used scanner Foxwell 624Elite to check it.
Did you recently replace your battery? That many codes often occur when a main cable is removed or replaced and a good reset did not occur in the system. I’ve had odd codes like this clean up if I remove the negative lead for a few minutes then soundly apply it back on the battery without a lot of bounce or sparks. May work for you.
