2001 Ody started to having isle issues...the idle was jumping from1100-3000rpms....athe car would surge forward if i let off of the brake
.Now the TCS light is on...and the check engine light came on...Any ideas
Get the code read. It will tell you the area of failure. Read some of the posts on power steering switch broken wire, idle control valve.
I had this EXACT issue with my 2004 2 days ago, the code was p1129(maps sensor) and p0505(idle air control valve(IAC).
I bought the IAC last night and hope to get this in van today.
getting the sensor off is an issue for me at the moment. looks like 2 philips screws under throttle body. stay tuned .
just installed the IAC sensor and now it runs like new!!!!
it was a easy job, as long as you remove throttle body, vacuum lines etc..
the 2 philips head screws on sensor almost stripped, so beware, good luck.
