1 - 2 of 2 Posts
Thanks
While replacing Ignition coils, front middle coil was hard to remove. I finally pried it out but the rubber boot end broke and came off and is stuck in the hole on the plug.
Use a long nose plier, you should be able to get it out. I have done it. It should help put a drop of oil to lube it and priced out. You might still be able to take the spark plug off with the tip on it.
1 - 2 of 2 Posts
