All six coils on the 01 Odyssey are protected by a single fuse.
If ANY ONE of the coils fails, the fuse will blow and the engine wild stop.
To avoid being stranded (again), I installed a six fuse block, one fuse for each coil. The OEM Honda fuse is 15amp, so I used 5 amp fuses for the individual coils
The current flow is .. OEM fuse -> my 5 amp fuse -> individual coil.
The upgrade material cost was about $20. My labor about 2 hrs.
Open the wiring harness to the coils and look for a BLACK wire with a BLUE stripe. This is the common wire from the 15Amp Honda fuse. Cut this wire back toward the input end.. near the Drive's side end of the engine at the front Cyl head. Attach the hot end of the wire to the input terminal of the 6X fuse block. Attach the Coil ends of the wires to the fused terminals on the 6X block.
To re wire the rear bank coils, expose the wiring harness, cut the Black/Blue wires to the Coils and attach to the 6X block. I mounted the 6X block near the battery and with the fuses lined up to match the coils they serve.
I will be HAPPY give any additional help/information
M I K E
[email protected]
M I K E
[email protected]
