2003 Ody with 160,000 miles. Key will go into and out of ignition fine, but once in will not turn at all. Can pull out and in several times and sometimes will turn fine. There is no resistance to turning when it turns, just won't turn at all most of the time. I have tried lock-eze (graphite lub) but has no effect.
Have talked with my local Honda Service who want me to tow in and pay over $500 to replace the cylinder (maybe switch?) and reprogram the key. Local lock smith said he could fix and reprogram the key for a lot less.
Has anyone experienced this problem and/or removed the cylinder?
I have searched for the cylinder, but end up with the "ignition switch". Is this the correct part?
fwhitrock
fwhitrock
