Imitation HID Lightbulbs
1770 5
I am thinking about replacing the standard halogen bulbs with the brighter imitation HID lights. Does anyone have any advise on this and if so what brand would you recommend and did you notice a big difference? Thanks for the input.
1 - 6 of 6 Posts
I HAVE CHANGED MY BULBS TO THE PIAA HID SUPER WHITE THEY MAKE THINGS A LITTLE EASIER TO SEE IT USES WHITE LIGHT AS APPOSED TO YELLOW BUT YOU SHOULD 'NOT' BUY THE SUPER PLASMA BULBS YES THEY PRODUCE MORE LIGHT BUT THEY WILL BURN OUT WITHIN 6 WEEKS THEY PRODUCE TO MUCH HEAT (I BLEW 2 SETS BEFORE I CALLED PIAA) ALSO THE BULBS ARE WARRANIED FOR 3 MONTHS AFTER YOU BUY THEM IF THE STORE WONT REPLACE THEM PIAA WILL
Usually when bulbs burn out that quickly it is because the bulb surface was contaminated. If you touch the bulb, for instance, oils from your hand will cause it to burn out very quickly.
1 - 6 of 6 Posts
