I am having trouble getting this feature to work. My pic is saved in jpeg format & the resolution has been set to what the manuel suggest but still no luck...has anyone else had this problem or been successful with this? Thanks! :)
try lower resolution. i didn't even check the manual but when the initial size didn't work, i just used around 640x480 and it worked. love having the family picture driving home -- wish it'd do screen saver mode and automatically switch through them but it'd probably be too distracting.
The 2011 Owner's Manual provides some insight into Wallpaper setup on page 310, notably:
- If you choose an incompatible picture, such as one that is too large or in an unsupported format, a message will appear and the system will not be able to import the picture.
- You can only import images from the root directly. Images in the folders cannot be imported.
- The max file size is 1024 × 768 pixels. Smaller images are displayed with the extra area appearing in black.
- Larger images are reduced to a displayable size without changing the aspect ratio.
- Five uploaded images (in BMP or JPEG format) can be saved.
I imported a 1024x768 image and its still showed black bars along each side, which suggests that the actual screen resolution is actually better.
