1 - 7 of 7 Posts
Odyssey 2007 EX. I have intermittent grinding noise coming from engine compartment during light load/acceleration. It sounds very similar to judder problem of torque converter. I have torque converter replaced and ECU flashed many times – up to its most recent version in Honda’s dealership. I replaced steering pump (A03)/reservoir/pulley with the latest versions and flushed old PS fluid. Although whining is gone it still sounds too loud at higher RPMs but grinding/rattling happens only when car moves/accelerates. I checked heat shield for intermediate shaft as it described in TSB (even though my VIN is not in that range). I checked heat shield for catalectic converter too – all seem solid, nothing is loose.
Is anything else I can check? Any loose part? Any bearings?
Check the motor mounts. If any are broken, when under high torque the engine can twist itself to where it wasn't meant to go.
Check the AC compressor clutch bearing, easy to do once you slip the belt off a pulley, spin it and listen for noises. Mine was spinning OK but had some slight "grinding" noises and that caused a LOUD groan. but the fact its only at some RPM is odd...you can look at engine while someone revs it up.
I guess the only one to check on Ody '07 is that on the front, right?
I believe there are 4 in total. The front mount would be a prime suspect. Its telltale sign is leaking brown fluid. The passenger side mount is also notorious for tearing.
Best to watch the engine as you gently rev it, first in D then in R, with the brake firmly applied. Just a touch of gas is needed, definitely not a pre-launch roar.
Note that broken motor mounts often have other symptoms, such as rough idle and banging.
1 - 7 of 7 Posts
