JL Subwoofer for 2011 touring
3940 6
try to figure out if 13" subwoofer will fit our odyssey.
JL jx subwoofer amp 1000/1
JL 13w7 subwoofer driver
1 - 7 of 7 Posts
The sub box will only support up to a 8 inch subwoofer. There's not enough space to accommodate a 13 inch sub. I personally wouldn't recommend a 13 inch unless you plan on doing some customization that will require sacrificing space and looks.
My plan is to install the Alpine SWR-843D 8 inch unit. Also, you may want to look into the dimension of the JL amp. It may not fit. The stock amp is small and mounted vertically behind the glove compartment.
what is name brand for 2011 touring elite amp. i try to swap out my touring 240 watt into 600 watt or higher.
btw just add third row seat speakers today. happy with the result.
Shanti where you say you gonna put another speakers to make a surround sound?
The new 8" Alpine Type R is quite nice.
Do you already have an enclosure?
In my opinion the 13w7 is way overkill unless you are a basshead. It's a great product but very pricey. Also, the box will be quite big.
What is your budget?
Amp info
Do you know where I can find more info on the stock amp? I plan to upgrade myself. Just having a hard time deciding where to install a new Amp. I want to keep my space. Was looking into a 5 channel Amp, but if the stock Amp can provide what I need, no reason to buy a new one.
1 - 7 of 7 Posts
