1 - 9 of 9 Posts
I just got a 1995 odyssey this week, with 242k miles on it. It's driving ok, although it seems to shift a little funny. I'm probably going to do a drain and fill with the tranny fluid, but I was wondering if there are any "normal" known problems with these year vans. For example, many models of the acura tl have known transmission problems.
Thanks for any info...
Tranny chug is normal on these things. If its violent then it is a matter of cleaning tranny solenoid screens. It was also posted in Consumer Reports in 1995 for the Accord and the Odyssey
Discussion Starter · #7 ·
actually, i've been searching for about an hour and can't find a diy for cleaning solenoids. I've found one pic of a clogged solenoid, but I wouldn't even know what to take apart to find it....
It's really easy. Shift solenoid is to the right of the dip stick, and the lock up solenoid is up from that and to the left. Each one has 3 10mm bolts, and a connector with 2 wires. Pull them off clean the trans surface, and the screens are part of the gasket.
1 - 9 of 9 Posts
