1 - 7 of 7 Posts
2007 Odyssey EXL
With help from the good folks here, this past week I:
Changed the oil.
Drained/filled radiator.
New coil pack and spark plugs
Cleaned PCV valve.
Replaced power steering high pressure hose.
Ordered new parts, Air hose, etc.
Tomorrow is drain/fill trans x 3
just trying to keep a 270K odyssey moving.
Awesome
What year and trim?
I am just 35 miles SE of you.
What year and trim is Van, .. please
Why did you feel you needed to replace coil paks?
Which coil paks did you use?
Manufacture?
Why not just replace PCV valve?
Keep us informed.
Reactions: WiiMaster
2007 Odyssey EXL
in Ohio now. driving 07 Odyssey EXL
Denso coil paks.
No need to replace pcv valve....just clean it and reinstall.
Cheers...
2007 Odyssey EX-L
Denso coil paks.
Cheers...
Wow, 270K! How long have you had this car and what major work has been done to it? Original engine, transmission, radiator?
Reactions: 0dyfamily
2007 Odyssey EXL
Original engine, transmission, radiator.
2 timing belts
transmission drain/fill
good oil often
1 valves adjust
1 alternator
1 starter
vcm muzzler
lower control arms
front axles
sliding door maintenance
replacing air hose and box when they arrive (yay duct tape!)
just replaced power steering hose.
just replaced coil pack and spark plugs.
seeing gas cap alerts now...wondering what sensor is detecting fumes?
I drive it like a granny
2007 Odyssey EXL
Discussion Starter · #7 ·
2 timing belts
good oil often
1 valves adjust
1 alternator
1 starter
vcm muzzler
lower control arms
front axles
1 - 7 of 7 Posts
