JVC KW-NT3HDT Install
Just thought I’d post about my install experience with the new JVC HD LifetimeTraffic Nav Head Unit on my wife’s 2006 EX. I also installed the Boyo VTL375 backup camera license plate, and PAC-SWI-JACK Steering Wheel Interface. First off, there were some great threads that helped quite a bit. I also have the Service Manual which also helped but the online service manual at helms would probably have worked also.
Here are a few threads that were really good:
Pioneer AVIC F90BT 08 EXL
Installed JVC KW-AVX810 Headunit
Reverse Camera Installed On 2007 - Diy
Bakup Sensors/Camera no RES
How to tap backup/reverse circuit when in reverse
Installing DRL, Need Wiring Diagram (Wire through firewall)
I’m just going to cover some of the areas which I thought were a little tricky or I had questions about before I started.
Wire backup camera
This was a complete pain in the rear and probably took 75% of the install time on this task. I had trouble with the rear right hand panel next to the third row seats. You have to remove the seat belt bolts and the C-pillarfirst or you’re going nowhere. Here’s what it looked like finally removed.
I routed the backup camera extension wire at the floor line and around the third row hinge and then back up the D-pillar. I also pulled all the panels off the back starting at the top, then the sides, then the bottom panel (pull the handle cover and screws first). I had a little difficulty getting the wire through the grommet between the D-pillar and tailgate but I used a coat hanger and finally got it through. I then had to fish the wire down the inside of the tailgate to the taillight section.
I then pulled the license plate panel off the tailgate but as it worked out I didn’t have to do it(wasted a fair amount of time there). I had lots of conflict trying to come up with the best way to route the wire from the license plate to inside the tailgate but in the end I drilled about a 5/16” hole I think right in the tailgate behind the license plate and installed the wire through it with the supplied grommet from Boyo. Here’s a picture of the hole and then wire mounted and shown from the back side.
I didn’t use the security bolts from Boyo since you can’t remove the threaded insert on the Ody. I just used the original bolts which worked fine. Here it is installed.
The cable from the license plate was just long enough to reach over to the taillight area to connect to the extension cable which is nice because it’s easily accessible.
Reverse Wire
Originally, I thought I’d have to run a wire all the way to the backup lights, but I found a thread (one of those I referenced) that showed, even on an EX, a reverse wire at Connector C504 under the passenger side kick panel. The wire is in Pin 12 (green wire) on the underside of the connector. Careful, there are other green wires on that connector that are not the reverse wire. See pic:
If you take out the panel underneath the dash on the passenger side and pull the lower glove box (at least pull the stops and arm just like when you replace the cabin filter) then you can easily route the backup camera wires and reverse wire to the head unit area.
I originally installed the PAC-SWI-JACK steering wheel adapter according to their vehicle specific instructions on their website. The instructions for the Ody have a note about installing a 560 ohm resistor (they do supply resistors with the unit) if the Mode button cannot be programmed. It turned out I did need to add the resistor to get the Mode button to be programmed. Another note, the remote control wire is located on pin 3 (white wire) of the main audio connector (Connector A, which is a 20-pin connector) and the remote ground wire is on pin 11 (brown). The Metra adapter cable that was sent with this unit did not have wires on pins 3 or 11 so I had to tap those wires behind Connector A. Just connect pin 3 to the remote wire on the head unit connector, and pin 11 to the ground (I just tapped the ground wire on the interface cable to provide extra ground connections).
The programming instructions for the PAC are a little tricky but it’s not too bad. The problem I had is I was trying to assume the Ch+ and Ch- to perform a Preset+ and Preset- but the JVC unit wouldn’t recognize the Preset functions. I was also trying to program the Mode button as a Band button function but that wasn’t recognized either. So, I settled for
Vol+ ==> Vol+
Vol- ==> Vol-
Ch+==> Seek+
Ch- ==> Seek-
Mode ==> Source
There’s also a slight delay with the PAC unit but I had one of the newer versions and the delay wasn’t too bad. Since, I wasn’t real happy with the button mappings, I thought I’d also try the Axxess ASWC steering wheel interface as it says it allows button remappings. The wiring and programming of this unit is much easier and it has an auto-detect programming feature that worked the first time. To make a long story short, after trying to remap buttons, I’ve come to the conclusion that the JVC unit does not accept the Preset or Band commands over the steering wheel remote wire. So, I’ve kept the mapping as above which is how the ASWC actually programmed them automatically. The ASWC does not have any noticeable delay either, so I’ve kept it in the car. I mounted it using Velcro on top of the right hand side air duct next to the head unit.
GPS Antenna Location
The GPS antenna was smaller than I anticipated which is a good thing. I mounted it under the dash behind the head unit as close to the windshield as I could reach(next to the light sensor). It comes with double sided sticky tape which seemed to work fine. Here’s a pic of the location. So far, the GPS reception has been fine – no problems at all with it mounted under the dash.
Microphone Location
There were some good threads on microphone location and I was deciding between the headliner and the instrument gauge area. I ended up installing in front of the instrument gauges by lowering the steering wheel and pulling the bottom of the trim out towards the steering wheel slightly which provided enough space to run the microphone wire and it turns out there are a couple grooves in the clear plastic instrument gauge facing so you can slip the wire in one of those without pinching the wire. Here’s a pic of the final location. So far, the sound is good in this location.
Antenna Connection
You need an antenna adapter to connect the Honda OEM antenna connector to the head unit. Only reason I bring it up is that the JVC instructions talk about a wire for a power antenna, so I didn’t hook it up since the Ody antenna is fixed. Result was terrible reception. It turns out the Ody antenna is amplified, so you need to hook the blue wire from the adapter to the power antenna lead on the JVC connector. Reception is great now.
VSS Wire
I had mixed feelings about whether I should even try to hook up the Vehicle Speed Sense (VSS) wire. The JVC unit works without it and I think just gave me one warning the first time we used the Nav function after the install. It is supposedly used to give accurate location and speed info even when the GPS signal is not present (tall buildings, underpass, etc.). I’m not sure if the adaptive sound volume control uses the VSS or GPS speed info. Anyway, all the info I could find on the VSS wire indicates there should be a Blu/wht wire from the PCM available (pin 29, connector A) either by the driver’s side kick panel or at the PCM (in the engine compartment. Unfortunately, the EX model does not have that wire connected since that wire is really for the OEM nav unit. However, after some research, I found that the Output Shaft Speed Sensor on this car is a Hall-effect type which produces square wave pulses between 0 and 5 volts which is what the VSS line is looking for. This output signal is located on PCM Connector B, pin 40 and called NC. So, I tapped this wire using a Posi-tap and tested it on an Analog Multimeter. Just going slow, I could see the voltage vary between 0 and 5 volts. Perfect! I then ran it in a wire loom to the firewall grommet just above the accelerator pedal. I poked a small hole through it and ran the wire and sealed with silicone. Pictures below should help.
Here is the attachment sequence:
Anyway, after connecting to the JVC, there is a status screen that shows the speed pulse count and it was running about 1800 pulses (per min?) @ 40 mph so it’s working.
I’ll post a review of the unit a bit later.
Wire backup camera
Reverse Wire
Vol+ ==> Vol+
Vol- ==> Vol-
Ch+==> Seek+
Ch- ==> Seek-
Mode ==> Source
Microphone Location
Antenna Connection
VSS Wire
